1655 power steering cylinder change
Does anyone know the cross reference part numbers for the large needle bearing and oil seals for steering shaft? I found the small bearing.
The upper bearing is Torrington (now Koyo) B-2416-OH. Lower is B-2016-OH. Make sure they have the OH. It signifies oil hole and the hole must be lined up with the grease fitting in the bolster.
Upper seal: C/R 14804, 1.500 shaft, 1.875 bore, .188 thick.
Lower seal: C/R 12330, 1.250 shaft, 1.500 bore, .125 thick.
(quoted from post at 03:59:10 06/20/15) The upper bearing is Torrington (now Koyo) B-2416-OH. Lower is B-2016-OH. Make sure they have the OH. It signifies oil hole and the hole must be lined up with the grease fitting in the bolster.
Thanks Mike I really appreciate it.
