Are these bearings (number 6) the ones that go inside the front hubs? Are they sealed or relube wheel bearing type bearings?
Mine started squawking just a little yesterday when I made a hard right turn in two wheel drive. The planetary has oil in it alright. I added more and got it right up to the bottom of the hole. I lifted the front wheels off the ground with down pressure on the loader and spun the wheel around after I topped off the oil. I'm not hearing any grinding noise,but that left wheel has just the slightest little bit of shuck to it. The right side is tight as a drum.
