Oliver 77 hydraulic pump and housing
I have an Oliver 77, Super 77 and an 88. All without hydraulics. I was pleased as punch to find the housing, controls and pump for only $99.00. (See pics below) I would like to know what "you guys" (I know...now politically incorrect, think would be the best candidate for the hydraulics? I thought the 88 but I am not sure. Thanks for all the help.
Cort, I would see if the pump leaks before I put it on. Mine leaked into the rear end and needs rebuilt. I sat it on two boards on a pair of saw horses and poured some oil in and it dripped out. Good news is there is a guy on this forum that has new parts for the pump if you need them his handle is centerplate. Greg
I have one apart at work right now. There is enough crud laying on the base if left in there it would have ruined the pump in short order. Also is there a pin hole showing on the left handle? I would take it all apart and check everything first!.
Centerplate, here is my pump that still needs fixed! I just wanted you to know I had to put that tractor on the back burner for awhile and will give you a call as soon as I get going on it.
