roy prins
how do you guys install a rear main seal and or the front crank seal -- seems a real pain in the rear -- 88 gasser new to the oliver -- Roy
In the rear you need to get the clutch and flywheel off. If you DON'T have a belt pulley you won't need to pull the motor. But you will need to pull the PTO drive shaft.
In the front, remove the radiator and pull the front pulley and probably the governor and pull the front cover.
I can think of a lot worse ones to do.
RT (my two cents)
