The priority valve is leaking from the hose or pipe fitting that goes in the open bore in the pic.
I suspect the previous owner blew a hose and rigged something up as it appears the 1" pipe adapter he used does not fit properly and i can't get it to seal with teflon tape.
The 1" ID bore has straight tread and a smooth section in the bottom that ends in a slightly tapered flat.It appears a fitting with straight tread and 0 ring groove at the end is used there
My parts book don't show a break down of the priority valve, neither does the repair manual.
My question,
does any of you have a valve handy that you could take that fitting out and post a pic of it.(i think any 55 series model has the same valve block)
Thanks
My question,
Thanks
