550 1960 oliver parts and hydraulics
hankscott294
New User
does anyone know where I can order parts for 550 gas 1960 oliver, using oliver parts numbers, I need hydraulic breather and transmission breather filters as well as hydraulic filter. would appreciate any help I can get. Also would like to know if axle housing is part of hydraulic fluid compartment?
The only place I have found is your local AGCO dealer. They are the only ones with the
hydraulic filter. As for the breathers, I was able to get one at the AGCO dealer, and the
other was obsolete. It's just a round fiber breather though, you could make one easilly
out of some foam or filter paper. Good Luck!
(quoted from post at 19:36:16 06/01/15) The only place I have found is your local AGCO dealer. They are the only ones with the
Thanks for the input, will try to find an AGCO dealer near me.
Some third party also stock for Oliver 550 parts: They often sell old new stock and third party. Some of them might be connected to AGCO. They are quite good for consumables and rebuild kits.
http://www.external_link/brand-oliverwhite.aspx
http://www.oliverparts.com/
http://www.external_link.com/Oliver-Tractor-Parts-s/8.htm
http://www.abilenemachine.com/oliver-tractor-parts/
To only name a few.
Depending on where you live AGCO parts dealers can be found from http://www.agcocorp.com/
There is also Ebay for used and impossible parts to find in the new or compatible.
Good luck
Some third party also stock for Oliver 550 parts: They often sell old new stock and third party. Some of them might be connected to AGCO. They are quite good for consumables and rebuild kits. I'm not related to any.
To only name a few.
Good luck
Some third party also stock for Oliver 550 parts: Just search for "oliver tractor parts" in google
Good luck
I found some on ebay as NOS items. They are small cylinders made out of some sort of composite material. Some guys use a paper element since the originals are not available as far as I know.
(quoted from post at 00:53:37 06/04/15) I found some on ebay as NOS items. They are small cylinders made out of some sort of composite material. Some guys use a paper element since the originals are not available as far as I know.
I got my hydraulic filter (part #100476AS) straight from local AGCO dealer. It is expensive, but shipping cost is included (as opposed to Ebay). I'm certain it will protect my system made of lots of hard to replace hydraulic parts and that it will last. AGCO are selling OEM and third party that are compatible with OEM. If it is the wrong material, il may just go trough the bypass valve, without any filtering whatsoever.
