Oliver Super 77 valve spring retainer rubbers
I have a Oliver Super 77 that I am working on. When I took valves out of the head, I noticed the spring retainer caps can be seperated into two pieces with a rubber seal between them. What is the nomenclature of that rubber item and where can I order them? Thanks.
it is a seal to keep oil from running down valve i would asume a dealer should be able to get them
Two years ago the Oliver/White dealer I went to told me they were no longer available. I call them an umbrella seal. I cut the intake and exhaust guides and installed perfect circle valve seals. You have to have at least a seal on the intake side or it will suck oil
I have these new ones on my 1956 Oliver Super 88 Diesel:
These are made for Mercedes-Benz truck engines.
Hendrik
