oliver starter brushes
Have you searched based on the starter manufacturer of your 1255 Fiat Oliver? If the starter is made by an import automotive parts company you may be able to cross-reference the numbers.
Otherwise, and this may sound corny but I've made a set of custom brushes before from a Delco for other starters. The Delco has large square slugs made of a composite copper material and are easily shaped using a bench grinder or file.
