Does any body have the part # for the seals at brakes. I pulled out what I thought is the seal, but it's only a case with nothing inside, no seal no packing, no nothing. And no seal in there. The seals I ordered have this number SKF 28687.
I went & had another look. Looks like what I pulled out are only dust caps. I think I can see the seal deep inside. Should I get a long screw & remove the seals this way, or I see 3 bolts holding the brake drum onto the body. Should I take the inner drum off,( the part that holds the discs & the actuator) then change the seals?
