ObsoElitist
I finally got to drive it round for an hour today and moved a few buckets of dirt and ground asphalt, and ripped out some concrete.
The rams leak, but not bad..
Major issue, governor is not working, some feedback might help me out. I have the instruction manuals for the HG and OC3 and the parts book for the OC3. My governor is the earlier non-bumper spring type., and I set the rod 1/4 inch forward of the hole according to the manual. The tractor has no "quadrant" like it did stock, but a different arrangement but still operates by moving the lower governor lever.
I have installed a Zenith carb and can set the throttle arm anywhere I want. When facing the engine from the right side, full throttle is clockwise. Is that correct? If I am wrong that would explain the problem.
Also, with the stock carb, what is the distance from the center of the throttle shaft to the center of the throttle rod hole?
If thats not it, and I take the governor out and find problems, does Zimmerman or anyone have parts for it?
