Oliver 252 disc parts
Just a standard 1-1/8"-7 tpi nut, then the bendable locking tab. I'd think your local Fastenal should have them on the shelf.
Called a washer in the parts book. Part number 237497B. You can access the parts books through AGCO, the tillage is under New Idea, not White. If you are in an area with a lot of Oliver & White equipment find a hedgerow special and buy it off the farmer. I don't remember stocking them as they're not really a wear item.
Its called an end block agco parts w237497b $33.80
Nut part number f36122
Do not have the part number for the lock.
