1800A trans oil over full
i went to check the oil levels and found the front oil level plug ....assuming the trans oil level plug.... over full be 2 gal...the second plug was fine..i also found the hyd oil very low..what cause this...
thanks mark
I would bet that it is one of the two replies already posted. We had a neighbor years ago that had the same problem. He put a petcock in the upper check plug hole. When he used it all day, at night he put a hose on the petcock and opened it to drain in a pail.
In the morning he would take a funnel and pour it in the hydraulic oil hole. Did that for years until the hydraulic pump quit.
Then he put a new pump in it. He must have had more hours in dumping oil than it would have taken to change the pump.
