1550 hydrapower
Mike(NEOhio)
Location
Newbury, Ohio
I backed it out of the shed today. Jacked it up and ran it with Diesel in the main case to flush. Back into the shed to drain and I had a small puddle of ATF. It's been parked there all winter and not a drop. It look like it's coming from the area behind the filter. Isn't that supposed to be a hose? PO put a piece of brake lined in its place. One end seems to be loose in the housing. Is it an O-ring seal? Didn't have my camera with me.
3/8 steel line with a flare on both ends(similar to JIC),
Maybe all it needs is tightening the nuts
