if it rains it pours with this 1550. took it to do some ground leveling with the loader.
all of a sudden I see I'm getting oil squirting up at me, not a big stream but bad enough. I look down & the oil is shooting up from where that big plug screws in to the little cylinder where it goes to the rad. I also tapped my power steering into it . every time I turn my power steering oil shoots up, also my loader is hooked up to the hydraulics at the rear of the tractor where the implements connect. So also when I lift the loader up or down oil shoots up. looks like right where the gasket should be. Is there a copper or other kind of gasket that should is there, & needs replacing? And it's squirting out of almost a pin hole. If I open that plug will a bunch of stuff come flying out? is there a restriction somewhere?
thanks in advance for any help.
