Oliver 1950 hydra power delete
I'm trying to locate a hydra power delete kit for a 1900 or 1950 with the 4-53 Detroit. Anybody know of any for sale? Any help with locating one would be appreciated.
I have a shaft from a 1800 2 pc shaft and coupler for middle but you will need the couplers and chain.
If you have a good machine shop contact, have them make a pair of shafts. You don't need the Oliver coupling, use a modern shaft coupling that is horse power rated (this is the center coupling not the transmission chain coupling). If you're into tractor pulling, use solid shafts, this makes it even simpler yet. All the hydra-power delete bell housing does is provide a dust seal for the clutch. Use your existing bell housing and fab a felt seal where the hydra-power bolts up with a plate and large washer.
Just a thought, good luck.
