Noisy 1650D transmisson
I have purchased a diesel 1650 Oliver with the under/direct/over . When you let out the clutch, there is a growling noise coming what sounds like the transmisson area. It does not matter if it is neutral or in gear, or what range it is. Does anyone know what is causing this.
Thanks
Does it make the noise with the clutch pushed in? If not, guessing maybe loose coupler
chain or input shaft sprocket(s) are worn.
