problem with 77 engine
DLMKA
My 77 still runs and starts fine, doesn't seem to have any unusual noises or loss of power but the last week or two been noticing a puff of blue smoke when throttling back and Saturday noticed a minor oil leak that appeared to be coming from the joint between exhaust manifold and cylinder head on #4. I'm thinking it's got to be something in the top end on #4 leaking oil into the cylinder. Don't get a puff off smoke at start-up indicative of oil leaking down valve guides. Any other suggestions short of taking it apart and having a look? I was going to check compression across all 6 holes tonight.
Check the plugs I'd say #4 is not firing
all the time. Just had an 88 do the same
thing drooling oil from #5 put new plugs
in and made it work for 20 min and no
more drool or smoke.
A common fault is worn inlet valve guides and/or wasted valve stem seals, allowing oil down the guide at highest manifold depression.
Usually get a blue haze at start up, if all the inlet valves are oily, rather than a puff of smoke. Likely a function of gas velocity past the valve, temperature and pressure at the time of
occurrence.
