I'm under the tractor and see what looks like 3 drain plugs and no fill plugs, but I may be confusing one of the drains for a fill. From what I've read, 4.5 gallons of 10w-30 should do it, but I'm not sure where to put it. It doesn't look like even the highest side plug I can find will take 4.5 gallons either.
Also I keep reading on power booster, but don't know what it is or if I have it. Is the rear split between two locations and seperate for oil?
Don't mind the wet, most of it is hydraulic fluid from the valves up top that I've yet to rebuild.
Here's the side plug and front drain plug:
Here's the rear plug just behind the rear axle:
[/img]
