Posts several days ago concerning the engine speed and ground speed indicators on the above tractors. There are two groups of those tractors, early and late production. Wiring is different between them 2-88 serial number break is @ 302 591 & 2-110 is @ 302 446. There are two operators manuals for the 2-110, 2-88 had a supplement for the original manual. Do you have the correct manual? The late Op manual will show the serial number break on the cover while you need the supplement for the late 2-88.
Lets start there and I will try to help you although it has been a long time since I worked with them.
