Super 55 clutch throw out bearing.
John-MI
Is there a way to grease the throw out bearing on a super 55? I know that on some of the older Oliver's this was possible, but not sure about
the Super 55. Thanks
(quoted from post at 06:44:34 04/17/15) Yes there is a zerk on the center frame on the left side I believe. It connects a rubber grease line to the bearing.
You might pull the inspection plate on the underside to make sure that the line connecting the zerk to the T/O bearing is connected. Mine wasn't and years of pumping grease into it just made a mess of the inside of the clutch housing. It is tight. but with a flashlight you can see what's going on.
