1850 Speedometer Again
super99
The new tachometer and speedometer cables came yesterday and I put them on, both work now. Not sure if it will be a problem or not, the tach cable is at least a foot too long. It curves around under the fuel tank instead of being fairly straight. When running, the needle isn't steady, it has a nervous twitch and the cable under the fuel tank jumps around. I tied it in 2 places to hold it still, but it still wiggles a little bit. Will this shorten the life of the cable?? The speedometer cable was $17 and the tach cable was $64. Chris
