I finally got to the bottom of my 1750 steering column not locking problem. Past owner had switched Saginaw unit with Char Lynn unit from something and had fabricated a new bracket to latch the steering column. The bracket had broken because of bubble gum welding. So I removed the dash after disconnecting the battery. I disconnected the wiring from the gages( marked the wiring with labels as I disconnected it), removed the steering wheel, got the broken bracket out and repaired it. Reinstalled everything. Steering wheel now locks properly.
But I found that the charging system now does not work after reinstalling the gage wiring and reconnecting the battery. The tractor has a one wire alternator that was installed prior to my ownership and the wiring does not match the book. The alternator required the engine to be revved up to start charging. I have double checked all the connections with a trouble light and they are good, tractor lights work, amp shows discharge when lights are on and when starting tractor, other gages work.
All I did was disconnect the battery prior to starting the job. I have replaced the battery previously and the charging system worked after the battery was replaced.
Any ideas on what to look for or troubleshoot would be appreciated.
