1600/1650 oil pump
rrlund
Just curious,will the oil pump from a 1600 gas fit a 1650 gas?
There's a cheap 1650 on CL,says they ran a loader tine through the pan and broke the oil pump. I've got a 1600 pan and pump here. Just wondered if it would be worth a phone call.
Good used oil pumps are all over the countryside. Pans are a little harder to locate, but still quite a few around. Not sure if the tangs are all the same for the distributer. Will check and post back.
Had a senior moment. A few years ago I had a guy bring in a 1650 with a cracked block.
Had a 1600 block and had no problems switching blocks in and out. Distributor fit fine.
