Fluid is very milky when leaking at the rear sticks which tells me that there's water in there. Since the cylinders have fluid on both sides, what's the best way to flush the system short of disassembling each cylinder?
With fluid on both sides, how much fluid are you really getting out and back to the resivour by just cycling the cylinders up and down?
I have some acting up cylinders and i'm thinking that may be the culprit.
