I started the 500 the other day to test the generator and new regulator,but I had the 3 point lever in the wrong position. It bent the daylights out of the new drawbar frame that I made.
I took it off today and straightened it,then made it more like the original so it mounts with the arms up instead of down.
I noticed that there was supposed to be a latch/pin that holds it up so it won't settle. Mine didn't have one,so I made one. You can see that in the upper left.
