super99
I took time this afternoon and took the speedometer drive on the transmission apart and checked the little gear, it is good, teeth not wore, so it has to be somewhere else. I'm starting to wonder about the drive cable. It is only a few years old, and has not had heavy usage, had to replace it when the chain coupler broke and took the old one out. Strange, the tach and speedometer both on this tractor are not working. Both acted the same, needle jumps all around and finally quits moving at all. I pulled both cables last year and greased them and both worked for a while and then started jumping around and quit working. I guess the next step is to unhook cables from tach and speedometer and use a drill to spin them and see if they work. Any ideas??
