Bison2010
NO the motor is not stuck. owner pulled it and said it smoked but would not start 40 yr. old fuel in it,probably would not help.
Hopefully that didn't wreck the injection pump. Most all of them have hyds, yours must have been added later judging by the
homemade tank, I can't tell if it has the right remote from the picture.
Did you see the gas that sold last month ?
Yes, how well did it run? I bid a little bit on it online but we don't need another, they are very tough to find though. I might have an extra hyd tank kicking around would have to look and see.
They came with a hydraulic pump yes. That one looks newer than the tractor and
the tank was mounted on the other side to clear the belt pulley. It had a long
rod attached to the left fender and the valve was attached to the tank.My
gasser was set up that way from new. Cool find. Wish I kept mine they are
getting tough to aquire Duane o.
Thanks Duane o that's exactly what I wanted to know its funny there was nothing in the owners manual its a 53 manual that came with the tractor.
