Traditional Farmer
- Location
- Virginia
Changing the hydraulic oil on the 1550 gas I took the coupler ends off the
the two remote hoses on the one side when I cranked the tractor fluid came out of both
hoses under pressure.Got the oil changed and put the ends back on hooked up a cylinder and
the cylinder worked just like it should.Does oil supposed to come out of the hoses when the lever is in the neutral position? And I wonder how it works like its supposed to with the cylinder?
