had to surface block deck pretty hard to fix the blown gasket damage ( not more then .020) , now im wondering how much clearance i need between piston & head, also valves to piston , i know its going to be somewhat of a guess how much the new gasket will crush down ,i do have old one that i could get a idea of firing ring thickness , if needed can these pistons just be turned down on the tops? i know valves on a race engine need .010 min. to piston , turbo diesel may need more for heat exspansion thow , thought maybe someone who has had this problem could share what they know on this topic , so i dont have to learn by a costly mistake
