smokydiesel
New User
I have a White 2-105 tractor with the Perkins diesel. The problem I am having is the the PTO will drop out intermitintly when Im baling or running the discbine. It usually does it when I turn or hit the brakes. I have checked the pressure at the remotes with a gage and its in spec. I have also checked the pressure while turning the steering and pumping the brakes with the PTO engaged . The pressure seems constant with out any drop. I also took the PTO valve apart to make sure nothing was broken inside. There is an adjusting screw on the bottom of the said valve but I cant find any info on what it changes. Any help would be appreciated. Thanks
