1850 speedometer
super99
The speedometer quit working on my 1850. The small gear on the front of the transmission is the most likely culprit. The chain coupler came apart a couple of years ago and took the drive cap and gear out and I replaced with used parts, the little gear was in rough shape when I put it in. I greased the drive cable last year, and shortly afterwards, the needle started jumping around and then quit moving all together. Any ideas where to find a good used gear??
In the photo adds there is a guy named Justin Goodhue parting out a 1750 I believe. Pretty sure the 1750 has the same speedometer gear setup. He may even have one from an 1850. Also try Randy at Maibach Tractor 330-939-4192 (pronounced mayball).
