Agco Meadow Green spray paint,,,,YUCK!!!
T-bird
The last time I bought AGCO Meadow Green paint in an aerosol can it was Basically John deere green ( Been Changed ) and did not match any of my oliver tractors. Very disappointed at the incompetence of AGCO,,,does anyone make and sell a good Meadow Green in a spray can?
I remember finding an ad for the correct paint color in a spray can in one of my oliver magazines but cannot find it now.
I agree with you 100%. I tried a can and the color was off, Also the quality of the paint and the way it sprayed was garbage.
There's a hardware store here called Builders How To Warehouse, sort of similar to a Home Depot or Menards that sells tractor paint in spray cans and by the quart. I'm sure I saw Oliver spray paint in their spray can section, but I'm not certain who the paint mfr is. Next time I'm there I'll look to see who makes the paint.
Van Sickle has paint in rattle cans. I buy mine at rural King in Olney Il. and there Oliver green is as close as you will find. They also have the older Oliver green. This is not the Rural King.com that has about 60 plus stores. This Rural King has 6 stores in Southern Il. owned by the George Jones family.
I agree on the comment about VanSickle. I've painted two tractors with it and various implements and it is as close as I've found. Most other off the shelf types are not that close. I also painted two tractors with AGCO paint (both over 5 years ago now, when it was better) and I cannot tell the difference between the VanSickle and Agco painted ones.
I tried some Rustoleum Paint that TSC was test marketing. Used both cans and gallons.
Tsc discontinued it. But, I see it advertised on google and going to find a supplier. The color is great in my opinion. But, going to have to see how it weathers. Does not chip easily.
Rustoleum now has Meadow Green in spray for something like $3.87 per can at Home Depot, or a 6-pack for $23. Pretty good quality paint and to get results like a high-gloss premium paint such as PPG Omni Urethane, just put a clear top on it.
TISCO paint is Van Sickle the part number for Meadow Green is TP220 the SP, QT, GAL for quantity. There is probably a TISCO dealer within spittin' distance of everybody on this board. Van Sickle tech will work with you on making custom matches as well.
I had the same problem with MM paint from agco. It kind of looked like paint does after it has been around a battery for some time. It was that color right out of the can. I took it back.
