Lift arms on 1555?
bv
I hooked up my chisel plow to my 1555 and my question about the 3pt claws on the lower links, are they safe I've never used these before, is there a change over arm to the conventional style? Thanks again
You do have Cat 2 balls on the lift arms right? Cat 2 balls are standard for the 1555 and the do make a bushing to go inside to use Cat 1 equipment on them. Oh they do sell Cat 1 balls for the Oliver's lift arm's. As long as the top latch on the claw is closed they are safe to use. I've been running Oliver's for many years and have never had a problem with the lift arm's. Bandit
If you go to a store to get some Oliver balls make sure there Oliver lift arm balls and not JD center link balls (used on 4020 center link), People get them mixed up all the time! If they have the balls see if they fit a Cat 2 replacement pin, That's the easiest way to know if there Oliver lift arm balls or JD center link ball. Bandit
