Center link attachment
Kuebeck89
Anyone know where I can find this centerlink attachment piece?
Need one for my 770 I think the 880,1550,1650 all are the use same size, or if anyone has the factory original and wants to sell it?
That unit falls into the homemade and handy category. Not sure what a 770 had, but 1550 & 1650 were totally different than what you have there. Chris
Looking at pictures was wondering if a
person made this bracket could you then
fit a 3 point post hole digger on ? Was
trying to come up with an idea for one on
a 1550 if the digger 3 point arm would
clear the pto casting it sure would be a
simple fix
I'm sure you could because you can make the area where the center link attaches to the exact width and size you need and if you had a plasma cutter you can notch it if need be to get you clearance to go up or down with your post hole digger.
Just got the OEM one from LarryH link_disallowed (KY). Might also try Keith 540-270-0198 (VA) -- he has alot of 770/880 parts from time to time.
