1650 Hydraulics
Married2Allis
Still have alot to learn about this tractor. The rear lift seems to work fine, but the seller wasn't sure about the remotes. In the IT manual I see where you test the hydraulic system relief value with a pressure gauge. Can you also test each of the remotes with a gauge (have a 3000 psi)? - thanks
I have the same question. But also my 3 point will only stay up when in the lift position. It will also drop when tractor is off. Thanks for any info.
Yes: you only need to test one. You also need to maintain an inch of free travel in your 3 point linkage. Don't be using the 3 point to check the relief valve setting.
Sounds good. Thanks very much, I need to check or adjust that free travel. When I pull the remote levers I can hear the pump working, it sounds strong. Is that putting a strain on the pump if no hoses are connected?
