77 switch and hydraulic cover and lever pic's
greg oliver
I got a few more parts for my 77 thanks to Ebay and Justin in Minnesota. I wonder if anyone has a hydraulic lever? I also have a pic of the switch that I think is original. This tractor had a larger hydraulic tank that I removed so found a cover on Ebay now I need a gasket and lever. Holy cow the photo's are huge!
<image src="http://forums.yesterdaystractors.com/photos/mvphoto17868.jpg"/>
I'll try again. Carb was also off Ebay from Colorado. I had to clean it and find a gasket so far works good. Having trouble getting pic's to upload.
Chuck, left side on the side. Did you see the 405 horse fuel injected Oliver engine on You Tube? Started out as 283 CID. Pics still not loading but are on Oliver tractor Facebook.
I am some impressed with the 77 engine I have and really want to try it at the pulls. Just need a few more things I tried making a deal on some pressed rims but hasn't called me back.
(quoted from post at 14:44:39 03/22/15) I got a few more parts for my 77 thanks to Ebay and Justin in Minnesota. I wonder if anyone has a hydraulic lever? I also have a pic of the switch that I think is original. This tractor had a larger hydraulic tank that I removed so found a cover on Ebay now I need a gasket and lever. Holy cow the photo's are huge!
&lt;image src="http://forums.yesterdaystractors.com/photos/mvphoto17868.jpg"/&gt;
I am making some side levers for the earlier Oliver Hydraulics. I hope to have some by next week, then I can post some pictures.
Thanks, I may check out a salvage yard this weekend and if no luck I will give you a holler. ;Pictures loaded this time
J will have to help you with that one. Both of mine have the mechanical lift and I think the switch is different on those.
