283 direct injection
tom upton
Just tearing into a 283 and found crank mains and rod bearings in decent shape. Looks like previous owner had recently rolled a set of bearings in it. I would like to save the expense of buying bearings but I am coming up with almost .004 clearance on mains. Rods are .0025 to .003 Just wondering opinions of you Oliver gurus? The journals are all in excellent shape
(quoted from post at 14:06:43 03/21/15) Just tearing into a 283 and found crank mains and rod bearings in decent shape. Looks like previous owner had recently rolled a set of bearings in it. I would like to save the expense of buying bearings but I am coming up with almost .004 clearance on mains. Rods are .0025 to .003 Just wondering opinions of you Oliver gurus? The journals are all in excellent shape
4 thou is pushing it. You got mike the journals and see if that is still within specs, if they are then i would replace the shells.
Not sure if it's the same on bearings for that motor, but in automotive applications, some brands run a little tight, some run a little loose, so a change of brands of bearings might tighten it up some. Just a thought.
