1800A bearings
Jshum40
Does anyone know where I can get main & rod bearings for a 1800A series 10 or 20 under? I haven't got the crank turned yet so not sure if I'll need 10 or 20 under
You need to use a thrust bearing for an 88 and have the shop drill the correct holes in it. Rod bearings should be no problem (CB-703 Clevite if I remember correctly). I need to think on the other mains. Memory is not what it used to be. J.
(quoted from post at 09:21:09 03/13/15) Does anyone know where I can get main & rod bearings for a 1800A series 10 or 20 under? I haven't got the crank turned yet so not sure if I'll need 10 or 20 under
I have a set of standards and 0.10 main bearings in stock. I do not know if I have a set of 0.20, I will check tomorrow.
Svehlak Tractor
512-633-5014
