880 hydraulic drop rate
elkcagg
I have a Paulson loader on a 880 Oliver tractor and I need to know how to slow down the drop rate of the loader that's attached. I don't have access to any manual at this time. If anyone here could post a pic or give an explanation where I could adjust I'd would appreciate that. Thank you.
You have to turn the adjustment screw in. It is located on the swivel on the hydraulic unit where the hose attaches to the pipe that goes into the hydraulic unit. Plan B would be to purchase a needle valve from a hydraulic house that has free flow in one direction and adjustable restricted flow in the other direction. Clear as mud? J.
