which engine back plate do i need
jaxx fan
I'm in the process of putting a 310 in a super 88. I bought tractor without an engine, it had bell housing but no back plate. Number on bell housing is K580A which back plate do I need to match. thanks in advancement for help.
88 had a small and a large bell housing I think gas was the small and the diesel was the large I'm not sure if the supers were all large or not if you have the large bell housing any of the back plates will work from a 88 large s88 large 770 880 1550 1600 1650 if you installing a 310 and using a heavy clutch for pulling you might want to use the 770 880 or later bell house from a tractor that had a straight drive shaft.
