overhauling a 310-T in 1855 , need some advice
from the oliver techs. here . 1st engine ran fine
all the way around , blown head gasket which in
return beat the block deck , so i need to know
what min. deck hieght spec. is from crank center
to top of deck , & or how much can be surfaced off
safely without cutting pistons , ive read so many
things on here some counterdict one another so
would like to confirm some things i think to be
correct ,
1-valves should project about deck @ int. .014 -
.029 exh. .026 - .041 (update 1977)
2-replace rod bolts & torque to 50 ft.lbs.-1 time
3-head bolt torque 210 ft lbs inner- 180 ft lbs
outer (updated from old 133 ft lbs ? )
4-replace pin bushing to 1 piece style
5-ballance rods & piston assmbly within 1 once
6-liner pro. .004 above deck
7-deepen oil pan sump & lengthen p/u tube
also should rods be bored true center to center ,
am i missing any updates to this engine , im at
the point now that my ducks need to be in one row
, i would also like to thank everyone who has
posted updates , ideas , & fixes that have kept
these 310's alive
correct ,
these 310's alive
