differance between 1855 1955 overhaul kits valve specs.
jasinpa
question i have is can a 1855 diesel be rebult to 1955 power with using the 19 kit & setting fuel timing to 1955 spec. or are there differances im missing here , book shows same injectors , pump is adjustable if need be , same pump with timing & torgue screw changes . same turbo on both , also can someone post valve pro. / res. specs. for the 310 turbo , i know there on here in a post but cant find them , service manual. shows everything but this spec. , ???
I replied to this on another post. Just be aware that the 1955 engine uses a stronger piston/ring assembly than the 1855. The 1755, 1855 and 1955's all have different piston/ring assemblies for that matter.
Oops, sorry. re-read your post, You already mentioned using the 1955 "kit" which I am assuming has the stronger pistons. Wasn't there some differences in the oil coolers and oil filters between the two also?
