super 77 compression???
Did you check the compression or are you thinking about making a compression test. Let me ask you this: Has your tractor been converted to 12 Volts. If you did the compression test, did you have the throttle all the way open and all six plugs out? Now I would be more concerned more how even the compression is between all 6 cylinders. Now you are probably thinking I am talking like a worthless political person. Answer me those questions and I will tell you what Oliver called for a minimum spec. If you have more variation than 10% I would make a cylinder leak down test. My 2 cents worth. J.
its original 6v system... I just wanted to do a compression test to make sure things are all good. It doesn't smoke or anything, I'm just curious. Thanks for the help
