What is a older unstyled 99 4 cylinder worth sheet
metal is good some in primer tires or ok ???? This
is 1 of the square looking tractors Its in running condition
heres photo of mine for comparison, front tires were usable but needed replaced, back rims were bad around stem hole from fluid. tin work was so so, missing side tins, paint was with a brush. radiator needed to be cleaned. engine was loose but not running, was running year before but was sitting since because radiator issue. got it for $2300 which compared to others I have seen on internet was on low side.
