IH to oliver rims
rrman61
Does anyone know if I there is a way I could use front rims(23.1-34) from an IH 1440 combine to fit on my 1950.I have two good tires on IH rims.
If it were tubeless I would.its been done before.was trying to save the trouble and expense of dismounting and remounting those big a•• tires
Get or have someone make a set of adapter to fit the rim and the tractor. They can bolt up both ways or can be welded to the rim. Being there tubeless you can brake down on side of the tire or remove the valve core to let the pressure that will built up in the tire when you weld the adapter in if you go that route. Bandit
