880 helical gear transmission
TASO
Long story short- we are overhauling my 1963 880 gas and we found the input shaft to the tranny with the splines nearly stripped at tranny end. Ordered an aftermarket shaft, coupler, snap rings, seal and gasket.
After pulling the hydraulic reservoir and getting a good look, there is a gear on the shaft in the tranny and there is a plastic bushing between the gear and the shaft. The parts book shows it as a phenolic bushing. Tim Smith says they are no longer available.
Does any one know where you can get one? Or does any know the dimensions to machine one either of phenolic or brass/bronze( which is best?)? Anyone run into this before?
Any help would be appreciated.
Thanks.
I was not aware there was such a kit.
Tim is looking into replacing the phenolic with brass and trying to find the dimensions to have it machined to. In parallel with his effort, I thought I would ask here too.
Thanks.
i hope you have better luck with the aftermarket input shaft than i did. put a new one in twice on a 88, finally went back to a shaft from agco, no problems then
