broken wide front end problems
My white 2-105 has a badly busted wide frontend...what frontends will all fit this tractor?also heard this to be a common problem on these?
I purchased a 2-105 with a badly bent front axle. It has a front end loader so I put it down to that , but parked beside my 770 it does not look much heavier! I took it out, straightened in a press, then welded a 1 1/4 x 6 inch flat bar along the bottom edge, along with gussets on the spindle housings. Painted it back up again, and it looks o/k. I have a 8 foot wide bucket on it, and have quite often had it 3/4 full picking rocks, and it is standing up. If you want I could take a pic and post it?
My dad had a 2-85, hit a ditch with it, thinking the replacement center section was from a 2-135, maybe a MM I can't remember for sure, all I remember was that the outer ends fit the replacement axle, and the "U" part and tube was much stronger looking, and heavier too. Our dealer back then told us that White updated this axle.
