young tractor
Hi guys,
I have been working on the pto of my 1655. I can't get it to shut off unless I put a tremendous amount of pressure on the arm. I runs at the same speed whether it is engaged or disengaged. When I took the cover off, the big snap ring was not in it's groove, so I put it back in the groove and it still doesn't disengage. Could it be adjusted too tight. I don't have a pull scale to tell how many pounds the lever is at. Is there another way to test it? Could I back off the tightness one notch and see if it helps? My only other guess would be the the brake washer is really worn. What do you guys think? Thanks again for your help
