1950t valve adjustment
Benelli
I am in the process of rebuilding a 1950t. I need to make sure I set the valves correctly. I would like to know the correct way to set them. Thanks
Ah a good old T! Did you have the head reworked so the valve protrusion is correct? Is this an early or late T? I need an engine number! A tractor serial number would be helpful as well. How good was the oil pressure before, What are you running for bearing clearance? I have more questions, but start with that
J, this is a long block from maibach. The head was redone And the protrusion is set to the correct spec. It is an early T dual air cleaner pipes. New oil cooler, water pump, injectors and a new injection pump also.
