Serial number confusion
jimisler
I just got a 77 row crop. Serial number has too many digits, or I'm reading it wrong 3401830 Before the number is 1SL and after there may be a figure, then a "D", which I presume means diesel. It is a diesel. It is stuck, but I think I know where to go there.
The before the number would be DSl not 1Sl which is for an early diesel. 340 183 is the serial number. The 0 is probably a C and then there should be 2 numbers (77) and then a letter which is the code for the transmission. DON' t try to turn the engine over unless you have an extra $1000 dollars to waste on the project.
